kegger mod
Old Apr 7, 2009 | 10:35 AM
  #21
Mowhawk's Avatar
Mowhawk
Originally Posted by dakotas ram
well, it blocks off hot air from coming in....if that helps or not and allows me to use my $35 non-egr headers
How are those headers holding up. Youv'e re-welded the connections right, and I imagine (hopfully) painted them? lol
Old Apr 7, 2009 | 01:05 PM
  #22
dakotas ram's Avatar
dakotas ram
i really dont know what my mileage is......yeah mowhawk theyre holdin up good......got em welded for $10 and painted....dont look that great tho
Old Apr 8, 2009 | 10:49 AM
  #23
BigRedRam95's Avatar
BigRedRam95
what do you guys thank so far
Old Apr 8, 2009 | 11:37 AM
  #24
dakotas ram
sweet, did you have it media blasted?
Old Apr 8, 2009 | 11:45 AM
  #25
BigRedRam95
no i just used a wire brush on a eletric drill
Old Apr 8, 2009 | 11:56 AM
  #26
dakotas ram
wow, i did that to mine, but nowhere near that shiny.....dont forget your alternator and accesory bracket, they shine up pretty good
Old Apr 8, 2009 | 02:09 PM
  #27
TruckinDodge's Avatar
TruckinDodge
This is my take on EGR (I could be wrong and I'm sure someone will tell me I am)
after having it described to my by several engineers and mechanics. Newer (2004 and up) Diesel engines have egr now except for CAT. I hope this helps you decide what you should do.
EGR Exhaust Gas Recirculation is about the worst thing you can do to an engine for either gas mileage or performance. It is and does what it says it runs exhaust through your engine intake to drop NOX gas and conform with emissions. Dodge took the EGR out of the magnum engines because they could meet California emissions with out it and thus improve performance and fuel mileage.
Blocking EGR on an engine that was built with EGR will have an effect and timing will need to be changed but I am not sure which way or if these engines will make the correction on their own.
I can see no reason to keep EGR unless you live in a state that does smog testing. I own a CA emissions 1500 and it has no EGR.
Old Apr 8, 2009 | 02:54 PM
  #28
dakotas ram
thats cool...do you know when it actually opens up? ive heard that when youre decelerating theres alot of unburnt fuel and it opens up to reuse that....any other times?
Old Apr 8, 2009 | 04:21 PM
  #29
TMS Bill's Avatar
TMS Bill
The EGR valve allows burned exhaust gasses to be reintroduced into the combustion chambers, diluting the air/fuel mixture. This cools the combustion process (less energy released). Cooler temperatures results in reduced NOx formation.
Old Apr 8, 2009 | 04:24 PM
  #30
wjxavier's Avatar
wjxavier
if this is the case, i might just block it off...or just delete egr all together.
