5.2 tb mod help
Old Apr 6, 2009 | 09:04 AM
BigRedRam95's Avatar
BigRedRam95
Default 5.2 tb mod help
Ok I got a tb from the bone yard and I am going to do the mad on it after I cut off all lips on the sides. I want to bore it to 50mm but do I go all the way down do I stop befor the plates. I know that it is tapered now. but it has a stop on the side so I dont thank it will mess anything up if i go all the way down. someone told me that the plates were 50mm but I dont know. where do I get bigger plates if there not 50mm
Old Apr 6, 2009 | 04:20 PM
BigRedRam95
help someone please
Old Apr 6, 2009 | 04:55 PM
dodgeram07's Avatar
dodgeram07
just take off the buttflys and measure them your self,, i beleive when i measured mine i got about 49mm and a hair or 2,, but we are talking mm it's very close
jasonw's Avatar
jasonw
Site Moderator
Unless you want to make new plates, I'd just go down as far as the plates and stop. I also believe you are correct, I think the stock size starts at 50mm and tapers to 47mm, so if you just bore out the 47mm part, you should be OK.
