alinment (bad)
got to get my truck alined pulling real hard to the right, was wondering if it ok with the tires i have on the dayton timberline mud turrain tires , perdy much stock tires from the truck but may be a bit bigger, how much do you guys get your done ??? and how many miles are you sopposed to get an allinment
You cant legally drive, thus nobody should take your advice about something like this. You're 14. I know you are young and don't know any better, but the anonymity of the internet is a huge veil to your ignorance. And I mean that in a good way, ignorance =/= an insult. You do contribute to this forum in a good way, and your eagerness to learn is a very desirable trait.
Tires have nothing to do with alignment. The only time you will notice a difference after a tire rotation is if you have a bad or slightly different tire.
I typically only get alignments when I need them. I went from about 14k to 40k without needing one.
i dunno , since i had it its never been done, and has 128xxx, and just got new tires and back are fine but front losing tread real fast and its just pulling to the right real bad, maybe i need to change something that went bad
Trending Topics
I would rotate them and get it alinged. I recentialy heard an ad for my local Ford dealership advertising that they could get your truck alinged better than when it came off the assembly line. Sorta sounds like BS, but I'm going to try it when I get the track bar re-built, new tie rods, ball joints, and sway bar bushings.
