Ditching the 180*
Old Apr 13, 2009 | 11:22 AM
  #31
Mowhawk's Avatar
Mowhawk
Originally Posted by sungod
I still haven't got an answer that makes any sense what the benefit is of running a 180 degree t-stat. It seems to me the risk of carbon build up and poor combustion from the lower temps would be more of a risk than any gains you would get.
The t-stat opens sooner letting coolant into the system earlier. Thus, letting the system run cooler sooner. If nothing is wrong with your coolant system it will also help prevent overheating.
Old Apr 13, 2009 | 11:27 AM
  #32
lv360ram's Avatar
lv360ram
There are 3 intrarelated factors with the CEL:
1. Ambient temp/time of year
2. Actual thermostat opening temperature.
3. Accuracy of temp sensor
After reading all the hype last year I installed a 180. Is was ok until cool evenings came in the fall then I would get a CEL. Pulled the stat and checked it in pan of hot water with digital thermometer. It opened at 178. So, I deduced the CEL was a combination of the tstat and the temp sensor being off by a few degrees.
I recently bought another 180 and checked it in a pan of water with the same thermometer and it opened at 183.
I believe the people who don't get a CEL were lucky to have a slightly higher than 180 opening and additionally a temp sensor that is a degree or two in their favor.
Old Apr 13, 2009 | 11:31 AM
  #33
Mowhawk's Avatar
Mowhawk
+1 when i checked my T-stat mine opens at 182. I havent had any problems with my t-stat so far and my truck runs like a champ.
Old Apr 13, 2009 | 03:24 PM
  #34
jasonw's Avatar
jasonw
Site Moderator
Originally Posted by Acapalic
my 160 hasnt given me any problems other than being stuck in open loop, No CEL`s no nothing. And ive ran this for a year now , through the cold winter.
Constant open loop will lower your MPGs. Are you sure the CEL just isn't burned out? Does it light up momentarily when you start the truck? (They are supposed to.)
Old Apr 13, 2009 | 04:46 PM
  #35
Acapalic's Avatar
Acapalic
Yeah light comes on , isnt burned out. I even have a code puler , When i say theres no codes, there isnt ;-) I dunno , guess my truck likes the thermostat.
Old Apr 13, 2009 | 05:08 PM
  #36
PartsChaser's Avatar
PartsChaser
I have a 180 in mine, had it for a full season now (hot and cold in Kansas) and havent had any CEL related issues. I changed mine after swapping heads after a bent exhaust valve last year. It hasnt caused any MPG gains/losses, just a little piece of mind maybe. Might all be in my head.
I have a dual electric fan setup on mine, on a switch, so I can run it with no fans in the winter all the time and still get it to run close to 200, so far, no issues at all.
Old Apr 13, 2009 | 05:57 PM
  #37
sungod's Avatar
sungod
Originally Posted by julianvdmeer
I installed the 180 T stat two weeks ago, and i drive about 400 miles a week, the truck runs better with this T stat and there is no difference in mpg, so i love it so far, no worries of over heating just drive the truck and last week i was in a big traffic mess so i had to drive 2 miles per hour for about 15 miles, and the truck stays at 180.
Define 'runs better'? You are saying it sounds better? Besies the 'peace of mind' improvement what is there? If you gas milage hasn't changed then what have you gained?
Why do you have no over heating worries? A thermostat on regulates minimum temp, not maximum. A 180 degree t-stat is not going to make any difference if you are in an over heating condition. When it is fully open, it will allow the same amount of coolant to ciruclate through the system as a 195 degree t-stat.
Old Apr 14, 2009 | 03:37 AM
  #38
julianvdmeer's Avatar
julianvdmeer
By no worries for overheating i mean: before i installed the T-stat my truck always was 220 F so i constantly looked at the gauge, now i installed the 180 T stat and for me i feel more secure.
And youre question why the truck runs better?
For my opinion the motor runs more smooth, but maybe this is something in my head ..
Old Apr 14, 2009 | 11:50 AM
  #39
dsertdog56's Avatar
dsertdog56
Mine used to run right around 205 with the 195 stat pretty much all the time. It would peak over 210 easily in Summer in Phoenix especially in city traffic or in 4 lo off road. I feared towing or hauling any kind of load. I might mention I flushed my system regularly, and had my cap tested to make sure it held 16 lbs.
With the 180 installed, a clean radiator and a good radiator cap it would barely get into that 210 mark under the same conditions, and only when sitting parked with the air on.
BTW, a few degrees cooler coolant is not only good for the motor, but better for your automatic transmission.
I absolutely cannot say that this mod alone made my truck run any better, nor did my mpgs improve. But they didn't go down either. It hasn't caused a carbon buildup either.
Old Apr 14, 2009 | 12:33 PM
  #40
Gary-L's Avatar
Gary-L
Veteran: Navy
Did it help you lose weight and prevent hair loss?
