Is there a trick to knowing when to remove the tape for the top of the bed rails so the liner coating is set enough vs. set too much that it's difficult to remove the tape?
As soon as you apply the second coat, pull the tape while it is still wet. The lining is thick enough to not run and it will be wet enough to not create a seam on the tape.
when I did the rocker panels I took a air powered sanded to the side and bed of the truck and my neighbor was washing his dodge ram. He looked over and gave me the weridest look cause i was taking a sander down the truck. I did that so it would stick better.
im gonna do it like i said, for the few reasons that it will look better than cutting thru a rubber mat when i put a hitch in, and my bed is scratched to ****
