oil pressure gauge problem???
Old 02-15-2010, 07:33 PM
notanexit7's Avatar
notanexit7
notanexit7 is offline
oil pressure switch and oil pressure sending unit is the same thing right?
Old 02-15-2010, 08:26 PM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
yes. its actually a sending unit (variable voltage), not a switch (on/off).
Old 02-15-2010, 08:27 PM
dhvaughan's Avatar
dhvaughan
Originally Posted by Gerehead8
The sensor is after the oil filter in the system but the oil filters have a bypass so that if they get clogged up the oil will still flow.
if it works...
Old 02-15-2010, 09:47 PM
Miami_Son's Avatar
Miami_Son
Miami_Son is offline
Originally Posted by asmara1115
Changing your oil pressure switch will yake care of your problem. It costs 9.99 at Oreily's.
I'm pretty sure the OP fixed his problem in the 10 months since this thread was started.
Old 02-16-2010, 07:03 AM
notanexit7's Avatar
notanexit7
He could be a procrastinator like me I've still got my leveling spacers and new shocks sitting in the back seat and I've had them since early december.
Old 02-16-2010, 01:11 PM
95MaroonMonster's Avatar
95MaroonMonster
95MaroonMonster is offline
yea, seeing as how he sold the truck...
Old 03-13-2011, 03:12 PM
slick54's Avatar
slick54
slick54 is offline
Default Clip on Oil sending Unit
Sad question, how do I remove the clip on the oil sending unit without snapping it. I tried using a reg screw driver to pry it but I did not want it to break. Any suggestions would be greatly appreciated!
Old 03-13-2011, 03:17 PM
matty675's Avatar
matty675
matty675 is offline
no special trick.... just be gentle.
its no big deal if it does break
Old 03-13-2011, 04:10 PM
slick54's Avatar
slick54
slick54 is offline
Well I managed to snap the front off the clip with a screw driver and I still cannot remove this clip from the sending unit, what gives? Any special tool or technique used to get this flippin clip off?
Old 03-13-2011, 04:38 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,189 Likes on 2,942 Posts
It should just pull right out...... should....... Contacts may have corroded themselves together.... Look forward to replacing the sending unit.
Grab the connector with a pair of needle nose, or, whatever other pliers you happen to have handy, and PULL. It WILL come out......
Quick Reply: oil pressure gauge problem???
