How to till gears and change speedometer
Old Apr 16, 2009 | 10:25 PM
slowram's Avatar
slowram
Default How to till gears and change speedometer
Hey im thinking of getting gears and cant decide between 4.11 or 4.56 but cant find out what my truck has. The sticker under my hood says i have 3.55s but on the gear calc stite says i have 4.11s. Because when im driving with over drive turned off im at 2400rpms at 60mph with 35s and jaws gear calc says this is 35s with 4.11s. But my speedometer is still right and i dont know if the guy who owned it before me put the gears in. Im also wondering if i do swich to 4.11s or 4.56s how do i get my speedometer correct its a 97 too.
Old Apr 16, 2009 | 10:30 PM
Cereal Killer's Avatar
Cereal Killer
jack the rear end up and put a chalk mark on your drive shaft, and another chalk mark on your tire. Turn the tire one full revolution and count how many times your drive shaft spins. If it spins 3 and a half times you have 3.55 years. If it spins a hair over 4 times you have 4.10 gears.
Oh and it would be a good idea to block your front tires when doing this.
Old Apr 16, 2009 | 10:35 PM
slowram's Avatar
slowram
oh thats that bad its pretty easy
Old Apr 16, 2009 | 10:38 PM
hutch1973's Avatar
hutch1973
I didn't realize you could change speedometer gears in our trucks. Can't tell you how happy I was to find out how simple it was to do in my TJ when I had the lift/tires installed.
Old Apr 16, 2009 | 10:41 PM
slowram's Avatar
slowram
how would i change my speedometer. Why do you think my rpms are already so high with overd drive off, this is why im scared to get gears cuz my rpms are alreday so high i wouldnt even want to imageien it with 4.56
Old Apr 16, 2009 | 10:45 PM
hutch1973's Avatar
hutch1973
I thought you needed a programmer, but I could be wrong.
Old Apr 16, 2009 | 11:13 PM
olyelr's Avatar
olyelr
Newer trucks need a programmer, older ones need a different sized gear in the speedo deal. I think '98 was the cut off.
Nothing is need in the newer trucks (when only the gearing is changed) due to the speed be read by the tone ring on the ring gear. But, when tire size is changed, the computer will need to be reprogrammed.
Old Apr 16, 2009 | 11:14 PM
slowram's Avatar
slowram
yea for 98-01s but they font work on 97
slowram's Avatar
slowram
whwere do i get this
Old Apr 17, 2009 | 11:20 PM
slowram's Avatar
slowram
Hey cearl killer i tired what you said and it didnt work i only got one and a half spins of the drive shaft so that cant be right. And Olyelr did you mean that i wont need to do any thing if i change gears in mine i just need to adjust it for the tires and how would i change it
