Rattle driving me NUTS!!!
Old Apr 21, 2009 | 09:52 AM
jgcox6's Avatar
jgcox6
Default Rattle driving me NUTS!!!
I have a rattle sound when I first start off...either in forward or reverse. It sounds to be coming from under the truck...Please give me suggestions...I can't stand it.
Old Apr 21, 2009 | 12:15 PM
01dabram20's Avatar
01dabram20
if you have duals check your clamps. one of mine broke off and took it to get it fixed this morning.
Old Apr 21, 2009 | 12:59 PM
wjxavier's Avatar
wjxavier
i actually had a rattle too, come to find out when i did my plug wires, i routed them around my tranny dipstick tube and it was hitting my valve cover/intake. re-routed wires underneath the tube and its gone
Old Apr 21, 2009 | 01:02 PM
Viper37's Avatar
Viper37
Exhaust clamps. Check them.
Old Apr 21, 2009 | 02:28 PM
postie1686's Avatar
postie1686
mine had one and it was the heat sheild by the cat
Old Apr 21, 2009 | 03:03 PM
dodgeram07's Avatar
dodgeram07
go tap the cat with a rubber hammer an see if you hear it. if not tap around down there
Old Apr 21, 2009 | 04:37 PM
jgcox6's Avatar
jgcox6
Isn' t that going to loosen stuff up in there? SO if I hit it and it rattles..then what?
Old Apr 21, 2009 | 05:53 PM
dhvaughan's Avatar
dhvaughan
either live with it, replace it, or gut it.
Old Apr 21, 2009 | 05:55 PM
dodgeram07's Avatar
dodgeram07
then you found your rattle
then you can deside if it's heat sheld or it's in side of the cat.
if it out side (heat sheld) weld or punch it
inside, new cat, gutt the cat, or y pipe
it very common on these ram truck to have a bad cat
