Accelerate - CLANK - Accelerate - CLANK
Old May 1, 2009 | 10:49 PM
  #21
95MaroonMonster's Avatar
95MaroonMonster
i replaced a U-Joint on my left front axle shaft, thank god for the heavy duty bearing press we have in the shop, popped the mother ****er right out, no hammer required
Old May 2, 2009 | 09:20 AM
  #22
Gary-L's Avatar
Gary-L
Veteran: Navy
Originally Posted by Rockyhigh360
+1 on the Spicer joints. Also, any joint with a grease nipple is not going to hold up against a solid one. Save the zerk type for your Civic
Really, does that same faulty logic apply to tie-rod ends and ball joints with zerk fittings? Regular lubrication will extend the service life of your parts. Never worked on cars much, have you?
Old May 2, 2009 | 10:46 AM
  #23
Rockyhigh360's Avatar
Rockyhigh360
[QUOTE] Really, does that same faulty logic apply to tie-rod ends and ball joints with zerk fittings? Regular lubrication will extend the service life of your parts. Never worked on cars much, have you?/QUOTE]
If you think a Tie-rod end or Ball joint is the same as a u-joint, Then no, I never worked on your kinda [B]cars[B] before. A zerk u-joint is hollow, a non zerk isn't, it's solid through out. Truck U-joints see more torque than a car. If you treat your truck like a car and use it like a car, then you will be using different quality parts. I guess it's servicability vs durability.
Old May 2, 2009 | 10:57 AM
  #24
hovie's Avatar
hovie
I worked at Dana Spicer but just got laid off and they will be located in Mexico by 2011 most deffinately.
Old May 2, 2009 | 11:07 AM
  #25
zman17's Avatar
zman17
Retired Moderator - RIP
Awesome! So you get the swine flu free with every purchase , lol. I can see the directions now, Warning, use safety eye wear,gloves and a mask when installing this product.
Old May 2, 2009 | 11:14 AM
  #26
Gary-L's Avatar
Gary-L
Veteran: Navy
If you think a Tie-rod end or Ball joint is the same as a u-joint, Then no, I never worked on your kinda cars before. A zerk u-joint is hollow, a non zerk isn't, it's solid through out. Truck U-joints see more torque than a car. If you treat your truck like a car and use it like a car, then you will be using different quality parts. I guess it's servicability vs durability.
Seriously, where do you get your information? The sealed joints aren't "solid". They're packed with grease, genius, and aren't fitted with a zerk fitting. U-joints, ball joints, and tie-rods ends all require lubrication, or didn't you know that's how they operate? Judging by your ignorance, you don't know that. Without grease, those parts fail, but by your logic, the non-serviceable parts will last forever. Again You don't know what you're talking about and should STFU.
Old May 2, 2009 | 03:14 PM
  #27
Rockyhigh360
Damn bud, who **** in your cereal? Thought it was a U-joint thread, not a pissin contest....
Old May 2, 2009 | 04:25 PM
  #28
dhvaughan's Avatar
dhvaughan
here we go again...
