2 bolts. take one dampner off. put new dampner on. might have to turn your wheels to the right when you install it. other than that the hardest part is getting the sticker put on straight (unless you put it on before installing the dampner)
Yeah, its pretty straight forward. Just so you know though, it is easier to turn the steering wheel then trying to push/pull the dampener to make it reach.
Yes, seems straight forward, but with my two left thumbs in can be a problem.
How is best way to break the tapered end? Is a pickle fork the way to go? My ball joint fork is too large, thus is there some special tool recommended?
dodge 1500 -- where did you purchase your front lights. Looks good. i'm deisel, think they will fit with the tranny cooler?
I got them from anythingauto.com there hella ff50 fog and driving light. I wish I had gotten the hella 500's. The only reason I wish I got the 500 is I'm doing a custom front end. There not bad. I would buy them agin! I would think they would fit just fine. The fogs are the outer ones the driving one are in the middle.
