More lift?
Old Apr 28, 2009 | 06:31 PM
Aubrey's Avatar
Aubrey
Then you'd use two of those spacers, one on each side to bump you up even. But I don't know if that will be enough since they all recommend 5" of lift for 35s. It might be ok if you don't wheel it though.
Old Apr 28, 2009 | 06:38 PM
Hoss98's Avatar
Hoss98
yeh if i can get them bout and inch you know that would be bout right but this may work. I can drive it now but if I go off road they tend to hit the wheel wells alot. I only really do some trail riding every now and then and nothing extreme. These trucks are great for the extreme stuff and I used to do it all the time but I got sick of driving it everyday with things being boken and all the body damage I was causing so I am fixing it up and building a mut truck from an old bronco II. I think mine was bigger than most trucks from stock. Its not an off road edition but its got the off road package. I ran 33s with stock suspension and no rubbing.
Old Apr 28, 2009 | 11:00 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Ill take that lift if you don't want it?
Old Apr 29, 2009 | 12:35 AM
Aubrey's Avatar
Aubrey
That spacer is Superlift #4250.
I have Skyjacker 3" 1500 coil springs available probably.
Old Apr 29, 2009 | 02:27 AM
dakotas ram's Avatar
dakotas ram
will they fit a 2wd?
Old Apr 29, 2009 | 09:38 AM
Aubrey's Avatar
Aubrey
Sorry, no idea on the 2wd trucks.
Old Apr 29, 2009 | 01:19 PM
Hoss98's Avatar
Hoss98
Well I am planning on keeping the 3" lift its really the perfect size for what I need I just need enough the keep the tires from hitting when im turning and hit a bump at the same time. So I just need to bump the front up about an inch or so. Thanks for the help Aubrey I might get those spacers.
Old Apr 29, 2009 | 01:26 PM
dodge15004x45.9
There a guy on pavementsucks.com got a new 3" body lift for 180.
http://pavementsucks.com/forums/view...p?topic=130431
Old Apr 29, 2009 | 01:33 PM
Hoss98's Avatar
Hoss98
yeh but I am not big fan of body lifts.
Old Apr 29, 2009 | 01:42 PM
dodge15004x45.9
Ok well is a cheap fix. But start cutting to make your tires fit then.
