Free parts truck, parts swap.
Old May 1, 2009 | 07:41 PM
Gwub2005's Avatar
Gwub2005
while we're on the headlight subject is it possible to just put a battery wire from a toggle switch to a relay and then to the headlights to use temporarily??
Old May 1, 2009 | 09:00 PM
helms's Avatar
helms
the headlight curcuit is controlled with a switched ground. it also goes through many relays and switches. i suppose if you spliced in right at the headlight relay and jumped it, you could use a toggle, but it sounds like a bit of a hack job
Old May 1, 2009 | 09:23 PM
Gwub2005's Avatar
Gwub2005
I'm thinkin of groundin the ground wire comin out from the light and then runnin just the low beams to a relay then battery then put in a switch wouldn't that just make my headlights like a big foglight and this will only be temporary
Old May 1, 2009 | 10:24 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Originally Posted by helms
the wiring is different, im sure you could rewire everything.... but is is worth it?
Hell NO!!
Old May 8, 2009 | 03:33 PM
RPU's Avatar
RPU
The bolt pattern for the seats are the same. The electrical is a pain. If you have nothing to do great. Otherwise....why would you want a wrecked steering bos???
