HO**Y C**P I need help
Old May 12, 2009 | 07:03 PM
Erik Kuijvenhoven's Avatar
Erik Kuijvenhoven
sounds like in the left back but its allot less now .... my tranny guy said it is deff a engine prob, that is the cause of the shaking in low rpm in every gear its like im going over small ruble strips......... anyone got some valuable input I bought a compression tester so soon ill have some results............. anyone know what psi it should be and how much diff the cylinders can be ????????????? THANKS GUYS
Old May 12, 2009 | 07:23 PM
ICEMAN_CH's Avatar
ICEMAN_CH
Your transmission fluid was black?????? Thats not good. What kinda of fluid did you put in there?
Old May 12, 2009 | 07:30 PM
97black_ram's Avatar
97black_ram
I would say between 130-150 since that was the range my truck fell in when I did mine a few weeks back. I would say about a 10psi range would be ok depending on how many miles is on your engine
Old May 14, 2009 | 09:43 PM
Erik Kuijvenhoven
One was 60 or 55 the other where at 150 any Ideas ???????????????
Old May 14, 2009 | 09:52 PM
PurplDodge's Avatar
PurplDodge
Those cylinders are screwed!
Do a leak-down test on those cylinders.
Wait a minute and I'll post instructions.
Old May 14, 2009 | 10:01 PM
SAVAGECITY's Avatar
SAVAGECITY
im too lazy to read whut you narrowed the problem to but im going to say it might be injectors or(not limited to) push rod(had a bronco with a noisey rod)
could be lots of things, hope you find it and get ur baby running like normal
Old May 14, 2009 | 10:03 PM
PurplDodge's Avatar
PurplDodge
From Rex-TheDOGG to me, re-gifted to you.....
Originally Posted by Rex-TheDOGG
You will need a regular sized compressor. Something that can put out 150 psi or above.
An adapter to connect the compressor hose to the spark plug hole. NAPA and some of the better auto parts stores sell these.
Remove the passenger side valve cover. Now is a good time to check for a broken valve spring on #2 or #4. Some on this forum have mentioned this happening to them.
First find TDC @ #1. The Haynes manual has a good write-up on doing this (pg. 2A-4 in my manual). Once you have TDC @ #1, you can rotate the crank bolt clockwise (as you face it) to TDC for any piston by simply following the firing order and counting each 90 degree mark on the balancer. The main TDC mark on my balancer is cut all the way across the balancer while the 90 degree marks are cut about halfway. Check to make sure that both rockers for the cylinder are all the way up. This will be the compression stroke.
Once you have TDC @ #4 or #2 (last in firing order), install the compressor hose Q-D male end into the spark plug hole adapter, and install the adapter in hole to be tested.
Connect the hose Q-D to the adapter and crank up the pressure as high as it will go.
Listen for air escaping at the different places I told you before. If it's the dreaded crack between the valve seats, then it may be blowing out the intake, exhaust, or both. You will definitely hear it or even feel it.
Let us know what you come across.
Old May 14, 2009 | 10:05 PM
Erik Kuijvenhoven
I made a new Thread pls look for some details there...
Old May 14, 2009 | 10:07 PM
Erik Kuijvenhoven
Thanks purple dodge I dont think I can do something that instense lol im a landscaper lol
Old May 14, 2009 | 10:11 PM
97black_ram
It's not that hard. A Haynes manual and some patience not to mention time and you can handle this job with help from all us members
