Suspension Lean???
Old May 10, 2009 | 06:08 PM
jasonw's Avatar
jasonw
Site Moderator
Originally Posted by wjxavier
i know a few of the guys on here have 2500 coil springs in the front. i'm thinking i might do that just for ****s and giggles. see if it doesnt do anything. i'm sure i can find them somewhere around here lol
The coil springs 99% of the time do not sag at all. The difference in ride height in the front of my truck, passenger coil spring is 1/8" higher than the driver spring. Not even noticeable.
Trust me, I ordered a brand new coil spring and grabbed a passenger side leaf spring from a junk yard. Can't remember if I was the original one who suggested it or if I got that idea from someone else, it was a while ago. Did the coil spring first, and it didn't make a bit of a difference in my lean. Replaced the driver's leaf spring, and now my truck leans to the passenger side about 1/4". Figured it evens out when I get in.
Old May 10, 2009 | 06:11 PM
wjxavier's Avatar
wjxavier
well i'm just saying, since they're 2500 springs, it might just stiffen things up a little more. just a thought
Old May 10, 2009 | 08:34 PM
97black_ram's Avatar
97black_ram
Could also just get a set of air bags for like $250 and have more carrying capacity and have the driver side aired up a little more than the passenger side to level it out. Just my opinion.
Old May 10, 2009 | 09:53 PM
95MaroonMonster's Avatar
95MaroonMonster
my half ton has no lean, but than again, i have a 2 inch add a leaf, and 2500 lb overloads so its pretty stiff in the rear (8 springs in the rear packs)
Old May 10, 2009 | 10:03 PM
97black_ram
I did the same. I installed a set of 2500 lb overloads because I haul a heavy trailer and a heavy mud truck. I love the stiff ride though.
Old May 10, 2009 | 11:02 PM
95MaroonMonster
i sure don't mind it, other than on one chunk of a road i drive on with large heaves, than it sucks nuts
i installed mine b/c farm work, next on the list is a gooseneck hitch
Old May 18, 2009 | 05:16 PM
brosnibean's Avatar
brosnibean
were did you get the overloads from? i have the lean, and it's pretty noticeable now that i have lifted my truck....was thinking about a new spring on the driver's side, but if i can find overloads for a decent price, i would prefer to fix the problem and add the weight for hauling
Old May 18, 2009 | 05:33 PM
97black_ram
Another solution could be coil over shocks from Rockauto. They say to increase your load capacity bt 1200 lb. I'm thinking about getting a set.
Old May 18, 2009 | 07:32 PM
95MaroonMonster
just be careful putting overloads on it, the truck won't sag as much, but the axle, frame, and brakes are no stronger then factory.
Old May 18, 2009 | 08:47 PM
97black_ram
Very true. You can add enough suspension to make the truck as strong a a 1 ton dodge but the rest is still 1/2 ton meaning just that.
The only reason I added the 3/4 springs was so my truck wouldn't sag evertime I hitch the trailer up. I only tow a few times a month otherwise I would have a CTD in my yard.
