Suspension Lean???
Old May 19, 2009 | 02:01 AM
  #21
Ugly1's Avatar
Ugly1
Originally Posted by 97black_ram
I love the stiff ride though.
That's what she said.
haha sorry!
Old May 19, 2009 | 11:29 AM
  #22
brosnibean's Avatar
brosnibean
Very true. You can add enough suspension to make the truck as strong a a 1 ton dodge but the rest is still 1/2 ton meaning just that.
totally understand, and I don't haul that much with my truck...the occasion load of mulch, hauling the camper 4-5 times during summer, pulling utility trailer with dirt bikes etc....i am really looking for a added stability with the camper hooked up, and to fix the lean....
so my question is will the 1000lb overload springs be sufficient to fix the lean, or should i go with the full 2500lb overload spring???? if I could save $150 while still accomplishing fixing the lean that would be kewl
Old May 19, 2009 | 12:49 PM
  #23
97black_ram's Avatar
97black_ram
Well there are so many options to fix the lean as you can see. Even though I have the 2500# springs I'm using only the first active spring in the pack since I don't weigh it down that much which gives me about 500lb of added capacity.
I only used the overloads because I had them available otherwise I would have went to the scrap yard and pulled a few off some truck and added them to the bottom.
Pick of the Ram hooked up to the trailer with my Chevy.
http://viewmorepics.myspace.com/inde...mageID=9922173
Old May 19, 2009 | 01:40 PM
  #24
wjxavier's Avatar
wjxavier
so if we wanted, we could just go to a junkyard, pull leaf springs and add them? its the same thing pretty much right? just have to get a longer bolt.
Old May 19, 2009 | 02:13 PM
  #25
97black_ram
I would look for a newer van or truck in the 3/4 ton range because the springs are slightly thicker and take both leaf packs from each side. I wouldn't worry about length if your willing to cut them. Measure the width of the leafs on your truck, they should be 2.5" IIRC.
If I remember tonight I'll take some pics of what I have done and post.
AutoZone has the longer bolts you'll need. They will need to be cut though, at least the ones I got needed to be.
Old May 19, 2009 | 02:17 PM
  #26
brosnibean's Avatar
brosnibean
i can't view your pic, i am not your facespace friend...oh ya, and i don't have a facespace account....
i would search the junkyards for a set of replacements, but i really don't have the time to go searching....so ordering the overload springs really is the "easiest" option for me at this point, just wondering if the 1000lb husky springs that bolt on the rear side of the leaf spring (behind the axle) would work for fixing the lean....anyone have any experience with this?
Old May 19, 2009 | 06:36 PM
  #27
97black_ram
http://picasaweb.google.com/lh/photo...eat=directlink
Old May 20, 2009 | 07:58 AM
  #28
brosnibean's Avatar
brosnibean
very nice...i ordered a set of 2000lb overload springs last night, hopefully it will take care of all my needs
Old May 20, 2009 | 08:31 AM
  #29
97black_ram
Thanks. My overloads take care of all my needs. I just worry about the axles a little since it's a 1/2 ton truck after all.
Old May 21, 2009 | 11:30 AM
  #30
joshokelly's Avatar
joshokelly
Where do you get these overload springs from, and is this a do it yourself kind of thing? I prefer to do stuff myself.
