Suspension Lean???
#31
Well this is an easy DIY kind of thing. I included some websites you can look at.
http://www.roughcountry.com/hellwig.htm
http://www.southwestwheel.com/supers...FRJ4xgodwUr0mA
http://www.suspensionconnection.com/...FRLoxgod0zsOlw
#32
an item of note, there are different styles of overload springs, some that require removing the u-bolts and others that don't....i like the idea of the one-piece design so i will have to remove the u-bolts to install them. this is not a big deal, but the item of note is that you should not reuse the u-bolts once you take them off, you should replace them....i just put a susp lift on my truck last week, so i am going to reuse the u-bolts, but in any other situation i would be replacing them
