Leveling kits all that difficult?
Old May 10, 2009 | 12:14 PM
vmann's Avatar
vmann
Default Leveling kits all that difficult?
Ive been told at work that putting a leveling kit on these trucks is a giant pain in the ***. Ive looked at a few sets of instructions and it really doesn't seem that difficult. Debating to buy this right now. http://cgi.ebay.com/ebaymotors/2-1-2...ayphotohosting
Dont want to buy something and not be able to put it on. Also how much do you think a shop would charge to put them on?
Comments, ideas, etc thanks
Old May 10, 2009 | 12:36 PM
BigRedRam95's Avatar
BigRedRam95
Thay are not hard to put on at all. It took me 1 1/2 hours to put my kit on. but I would get a 2 inch kit not a 2 1/2 inch this is the one I got http://cgi.ebay.com/ebaymotors/DODGE...1%7C240%3A1308
Old May 10, 2009 | 12:39 PM
vmann's Avatar
vmann
what not get a 2 1/2?
Old May 10, 2009 | 12:44 PM
BigRedRam95
Because I thank you have to replace the front shocks. And your front will sit higher than the back.
Old May 10, 2009 | 12:45 PM
pcfixerpro's Avatar
pcfixerpro
I was able to do the 2" without too much problem. That said, I don't know if I could have done it with a 2.5" spacer without a spring compressor. The install is not that bad at all but a buddy is suggested with getting the coils back in the perch after the spacer is installed. I used a crowbar to help compress the coil against the pearch... and a hammer to help aid it getting back in place.
Old May 10, 2009 | 12:53 PM
pcfixerpro's Avatar
pcfixerpro
I suggest replacing the shocks reguardless. I went with the 2" lift shocks in the front and they work well. As far as the sitting higher in the back... I still have another 1.5" of difference between the front and back although in my sig picture you can't tell. It is an illusion but I could have gotten away with the 2.5" level. I wanted something inbetween so if I have a little weight, the rear isn't saging too much.
Old May 10, 2009 | 12:56 PM
vmann's Avatar
vmann
wont the front sit higher regardless? I thought i would need a block or add a leaf to level it.
Old May 10, 2009 | 12:57 PM
zman17's Avatar
zman17
Retired Moderator - RIP
If you unbolt the stabilizer bar links, you shouldn't need to compress the springs.
Old May 10, 2009 | 01:02 PM
dhvaughan's Avatar
dhvaughan
if there's any doubt about spring pressure, you can't rent/borrow a coil spring compressor from autozone or advance.
Old May 10, 2009 | 01:03 PM
BigRedRam95
with 2 inch my truck sits level
