? about coil springs
Old May 13, 2009 | 03:30 PM
CSXfan's Avatar
CSXfan
Default ? about coil springs
Hi all,
My '99 4x4 has a serious suspension problem. It bounces around like a pogo stick on anything but smooth pavement, and the front end often bottoms out when I go over a dip in the road at speed.
I just bought 2.5" coil spacers and 2" add a leafs so I could get a little lift, and I'm going to install 4 new (lengthened) shocks all the way around. My question is, do I have to replace the coil springs up front too? Or will the new shocks give me a stiffer ride so the front end wont dive so much? I need to make the front end stiffer cause it's getting BAD.
Old May 13, 2009 | 04:05 PM
97black_ram's Avatar
97black_ram
Originally Posted by CSXfan
Hi all,
I would start by checking a shock. If you pull one off and push down on it and it compresses easy, it's shot.
Old May 13, 2009 | 04:06 PM
zman17's Avatar
zman17
Retired Moderator - RIP
It sounds like your shocks are shot. New ones will take care of it. The springs hold it up and the shocks keep it from bouncing.
Old May 13, 2009 | 05:11 PM
Miami_Son's Avatar
Miami_Son
Compression and rebound are controlled by the shocks. Springs are generally for load and ride height. Spring rate determines the force needed to compress the suspension, but the shock will determine the speed at which it compresses and extends. Bad shocks will cause the springs to react uncontrollably to impacts.
Old May 13, 2009 | 05:40 PM
zman17's Avatar
zman17
Isn't that what I said?
Old May 13, 2009 | 05:45 PM
ophidia's Avatar
ophidia
+x on it being the shocks.
Old May 13, 2009 | 07:21 PM
dhvaughan's Avatar
dhvaughan
yeah but miami used more words.
Old May 13, 2009 | 07:24 PM
charlie1935's Avatar
charlie1935
Short version-Get new shocks!
Old May 13, 2009 | 11:21 PM
CSXfan's Avatar
CSXfan
Thanks guys looks like I'll be getting new shocks for sure now. Any suggestions that won't break the bank?
Old May 13, 2009 | 11:33 PM
Miami_Son's Avatar
Miami_Son
I'm a technical writer and get paid by the word.
