Engine Issue
Old May 13, 2009 | 06:26 PM
97black_ram's Avatar
97black_ram
Default Engine Issue
OK guys. So I am losing coolant into my engine.
I've replace my head gaskets a month or so back, and no i didn't have them machined so, yes they could be warped or cracked.
I've replaced the water pump and timing chain so the front of the engine has new gaskets and all.
I did a compression test and all is good and pressure tested the cooling system and it held 13 psi no problem.
I re-did the intake since i was going to install the hughes kit anyways and that's only been a week. so the gaskets should be fine there.
So where or how am I losing coolant into the block? Cracked head, cracked block, open to any suggestions, I'm out of ideas.
Old May 13, 2009 | 06:46 PM
dhvaughan's Avatar
dhvaughan
are you getting coolant into the oil ? (milky color)
or is it just disappearing ?
Old May 13, 2009 | 06:49 PM
97black_ram
Well the dipstick doesn't tell me much. The air breather on the driver side valve cover has water in it and the oil cap has some yellow stuff right on the bottom.
Is there something I can add to the coolant to possibly seal this leak?
Old May 13, 2009 | 07:30 PM
wjxavier's Avatar
wjxavier
for the love of God, dont put stop leak in your coolant system. thats only for emergencies IMO. i think they do however make a coolant dye or something of the sort, so you can see where its going.
Old May 13, 2009 | 07:44 PM
PurplDodge's Avatar
PurplDodge
Arent you the guy who didnt install the head bolts in the correct order when you replaced the gaskets?
Old May 13, 2009 | 07:46 PM
97black_ram
It was just a though. I know it can create more problems than it will fix.
Coolant dye is great and all, but how can I see it if the problems on the inside?
Old May 13, 2009 | 07:48 PM
97black_ram
Yep, I would be that guy.
Just for the heck of it, is it possible I created my own problem by not getting the heads checks and machined and then torqued them in the wrong order?
Old May 13, 2009 | 07:54 PM
PurplDodge's Avatar
PurplDodge
Yeah.
Old May 13, 2009 | 08:08 PM
97black_ram
OK. Would I notice any engine issues other than coolant lose if I had a cracked block or head? Just checking for more opinions.
I'm willing to do the heads again if that will solve the problem. I'm getting pretty good at pulling the heads. I get faster each time I do it. lol
Last edited by 97black_ram; May 13, 2009 at 08:09 PM. Reason: forgot a small detail
Old May 13, 2009 | 08:19 PM
PurplDodge's Avatar
PurplDodge
Just make sure to get a torque wrench, and your Haynes manual. It has the proper torque specifications and torquing patterns.
