buying new ring and pinion
Old May 13, 2009 | 08:42 PM
01dabram20's Avatar
01dabram20
Default buying new ring and pinion
I did do a search but i didn't find anything out. I"m getting ready to regear my truck for a lift i'm going to buy in the winter. I was wondering if i can use the same differential carrier with the new ring and pinion or do i have to buy a new unit? I"m going to go with 4.56 gearing. I'm going to get a 5in lift and 35 inch tires.
Old May 13, 2009 | 08:55 PM
lockpickr's Avatar
lockpickr
The rear will be fine. You'll have to change carrier on the front or buy the thick ring gear. I went with 4.11's thick gear, no problems. I too have 35's and wished I had gone with 4.56's.
Old May 13, 2009 | 09:18 PM
kilaman's Avatar
kilaman
Yep I have 4.56 in my truck with 36's. It does great pulling a bike and tailer 80 mph all day long!!
Old May 13, 2009 | 11:06 PM
01dabram20's Avatar
01dabram20
I have the limited slip in the rear. So if i go with thick gears i will be fine then?
Old May 14, 2009 | 05:18 PM
acsamples79's Avatar
acsamples79
has there ever been any problems from thick gears?, i talked to my 4X4 shop about them and he said from his experience they tend to be more noisy and wear out faster. plus if you just buy a bigger open carrier it would be about the same price as the thick gears
Old May 14, 2009 | 10:41 PM
01dabram20's Avatar
01dabram20
yeah it will be nosiy but i could deal with that, but i don't know if it will wear out faster or not.
Old May 14, 2009 | 10:54 PM
dodge15004x45.9's Avatar
dodge15004x45.9
At least U know tht u should get 4.56.
Old May 15, 2009 | 12:25 AM
froesen's Avatar
froesen
There is only one carrier for the 9 1/4" rear. The front D44 has two different ones, but I discovered that the dodges came factory with all the same carriers, the lower geared ones used the thicker gears factory. I used the thick in the front with my 4.56's, no problems...
