rear leaf questions
ok, i got my 98 ram, want to get the 7 inch lift out of the rear, could get the skyjacker new leafs, but i am pinched for green, so i want to do the shackle flip, my only question, can i do the shackle flip, then 2 or 3 inch add a lef and get my 7 inch?
obviously with the zero rate block aswell
the cheapest way to do i think would be get a 5" rough country lift $700. then get the skyjacker 2" add a leaf for the rear $65, and then go with a 2" coil spacer for the front from topguncustomz.com $50. so just over $800 thats what im going to do to mine. but be ready to spend money on a new high angle front drive shaft or be ready to take it out and grind on it like i did. even with mine only being lifted 5" right now in 4 wheel it would bind up a bit.
All springs would be nice (and much more expensive), but the shackle flip will make the suspension a bit more flexy (from what I have read, no first hand info) and full leaf springs would most likely stiffen things up. So my guess is the rear will flex/articulate better the way you are wanting to do it.
Whats your plans for the front suspension? 7" Skyjacker coils? What control arms?
Yep, you sure can. Sounds like a good way to get a total of 7" in the rear.
i needed to know this because i was going to buy the rear spring pakcs but they are expensive as heel compared to everything else, and i fi get a better ride and more flex out of this. i will...
not to mention i am going to be putting the D60's under this truck due to locker and gear options, and i wouldnt run mor ethen 35's on the stock D44... so yea, that also helps
anybody got the link to a good shckle flip kit for or trucks?
i looked on bds but couldnt find it. maybe im retarted
and as for the first response. i will get my 7 inch lift and not have to grind the driveshafts, or by new ones just yet. its called a reindexing ring. it fixs that..
i mean i am sure i will need the tom wood drive shafts hee after a little while but for right now. im good
Trending Topics
well, i used to drive a 4 cylinder, so to me, the V8 is plenty of power, but if i had to say it, my 318 beats m buddies 350 everytime, probably cause all i run right now is the 31's buckshots, so to answer the question, not really, but i want to up the power a little so i will be going with 5.13's and may just do a good rebuild on my motor, put a good intake exaughst and then just a programer. should be fine
Its a pain in the @ss to find the BDS shackle flip on there site. You have to click on "order by P/N" under "products", and then enter the part number in the box (which is 012509) and click add, then it will show up. Its $235.56.
