Turns on then won't
Turns on then won't
K still cant get my truck to run I got it to run fine for about 3min. then it died and then it wouldn't turn on didn't even seem like it was firing.....yes there is spark yes there is oil pressure, no there aren't any codes....I am so fed up with trying to get this stupid thing to work!
8months of rebuilding and nothing to show for it grrrrr
heh alright better now
Perhaps a coil? I do have the infamous accel coil and it is brand new like everything else.
Jason I don't think its the fuel b/c I have had it running strong and smooth but then I turn it off and then turn it on and it doesn't even seem like its sparking(although there is spark I checked) Ima pull the coil off and go get it tested and maybe grab an msd coil.
I'm thinking fuel pump as well. When you turn the key, can you hear the fuel pump engage (make a sound)? test the coil and see if it's still good. I bought an MSD stock replacement coil and it died on me 3 months after I got it!!! Then 2 months after, the coil wiring harness started to go hay-wire on me so I spliced it and put a new one on. Just a couple of thoughts to get your wheels turning.
when it won't run, can you check fuel pressure at the scrader valve thing on the rail.
also, has it been sitting for awhile. might have condensation in the gas tank. likely.
or rust in the fuel rail.
when it won't run, you might test for no fuel by spraying in starting fluid or a small splash of gas down the TB.
Trending Topics
...how do I check the tps ?...
...and how do i adjust it the coil is good.
How did you check the pump? To properly test it, you'll need a fuel pressure test kit (gauge) that is capable of reading up to or beyond 50 psi. But before you hook that up, you'll have to relieve the fuel pressure in the system somehow. The proper way is to pull the pump relay and run the truck until it dies, but you obviously can't do that if the truck won't run. Anyone have any ideas?
