Air cleaner ?'s
Old May 15, 2009 | 07:13 AM
Bonesjackson's Avatar
Bonesjackson
Default Air cleaner ?'s
I see a lot of you run the regular old chrome air cleaners on your trucks and I was thinking about doing the same. Question is, I have a throttle body spacer on mine like many of you and wondered if a regular chrome air cleaner would fit? Also, is the throttle body the same diameter as a 4 barrel carb? I dont wheel my truck and my stock air intake stuff is all cracked and taped and figured this would be an economical option to a FIPK. Thanks
Old May 15, 2009 | 07:24 AM
JackJ's Avatar
JackJ
Ditch the spacer, they are crap.
Old May 15, 2009 | 10:42 AM
dsertdog56's Avatar
dsertdog56
OP, to answer your ?, yes the diameter is the same as a standard 4 bbl carb (5-1/8 inch). I would also ditch the TB spacer and it will make the install easier.
There are several threads on how to instal a 14x3 so I won't go into symantics. Use the search feature if you need help once you get the required pieces.
Old May 15, 2009 | 11:01 AM
Sheriff420's Avatar
Sheriff420
+1 its a stupid mod that does nothing for our trucks.
