radiator leak only parked nose downhill
Old May 17, 2009 | 09:55 PM
kevdawg327's Avatar
kevdawg327
Default radiator leak only parked nose downhill
Hi guys,
I have a 99 2500 2wd that has had a squeeking pully for the last 6-9 months, worse when it is cold outside, and today I noticed heavy leaking when I parked the truck nose downhill, it was more severe the steeper the slope, and finally I had the bright idea to park it uphill, and the leaking stopped, just some drips from it already being wet. I am thinking maybe a seal around the pully might be the problem, since all the fluid was falling off of the lowest pully. Any ideas and suggestion would be greatly appreciated.
Thanks,
Kevin
Old May 18, 2009 | 01:49 AM
J415's Avatar
J415
Explain yourself a little more thorough. make sure your coolant is topped off.
Old May 18, 2009 | 07:09 AM
dhvaughan's Avatar
dhvaughan
i'd guess water pump.
