screw driver in tire
Old May 18, 2009 | 10:29 PM
  #21
MAJohns's Avatar
MAJohns
the best thing for you is solid rubber tires no air pressure and never a flat!!
Old May 20, 2009 | 10:35 AM
  #22
sungod's Avatar
sungod
Originally Posted by Cereal Killer
Also, tread seperation is usually caused by going too fast on under-inflated tires. More air pressure will keep that from happening.
No, tread seps are usually caused by old tires. Driving too fast will not cause your tread to seperate unless you are driving more than the speed rating at the maximum load of the tire for more than an hour. In a dodge truck that is not realistic. Under inflation will damage the sidewall, not the tread. The other thing that causes tread seps is improperly repaired tires. Water can cause the belts to rust and then they will come apart.
I assume in this situation that since the tires were used, they were probably old.
Old May 21, 2009 | 01:07 AM
  #23
J415's Avatar
J415
In layman's term, going to fast.
Old May 21, 2009 | 08:57 AM
  #24
aim4squirrels's Avatar
aim4squirrels
Originally Posted by Steel Horse
I found 100 dollar bill next to the tolit at a Brooks & Dunn Concert!! OH YEA
And you probably had to use it at the Dr.'s office from the foul disease you picked up from it.
Old May 21, 2009 | 10:47 AM
  #25
Steel Horse's Avatar
Steel Horse
HAHA...nope i just boght sh*t loads of hot dogs and soda at the concert....OH YEA
Old May 21, 2009 | 06:18 PM
  #26
el_oso's Avatar
el_oso
When I read the thread title for some reason I was thinking you had a screwdriver inside the tire ....
