screw driver in tire
Old May 18, 2009 | 12:34 PM
Steel Horse's Avatar
Steel Horse
Angry screw driver in tire
So my luck with tires arnt so great. I bought some used BFG Mud tires, set of 4, well a week later the rear right tire blew on me. The tread seperated...Ok so i take it back to the shop i got em from and have em put another one on. OK....a week later the rear left one blows, cause the tread seperated. Ok so im done buying used tires. I go down to Discount tires and buy some new Nitto Terra Grappler AT. Well, not even 24 hours go by and i have F***ing screw driver stickin out of my side wall!!! WTF . Thank god i have life time warrenty.
Old May 18, 2009 | 12:45 PM
Laramie1997's Avatar
Laramie1997
How the hell did you manage that?????
Thank god for road hazard warranty
Old May 18, 2009 | 12:52 PM
Cereal Killer's Avatar
Cereal Killer
So did you back over it or something like an accident or did dick head stab your tire on purpose?
Old May 18, 2009 | 12:55 PM
Steel Horse
to shove a scew driver into a tire like that, you have to have some strength. So im assuming i ran it over just right. And if i knew someone did it, i would have asked to keep the screw driver and killed the little bastard with it.
Old May 18, 2009 | 01:02 PM
J415's Avatar
J415
I'm just curious, but what are your driving habits? are you a fast driver?
Old May 18, 2009 | 01:16 PM
lv360ram's Avatar
lv360ram
yea, sometimes I drive fast.
Old May 18, 2009 | 01:25 PM
Steel Horse
I get 9 miles to a gallon!! That tell you anything. And yes im 19 what do you expect. Im the king of the road . Not really but yes im a crazy but, safe driver. Especially when my son is in the truck!!
Old May 18, 2009 | 01:27 PM
Cereal Killer
It tells me you probably have a leaking plenum gasket
Also, tread seperation is usually caused by going too fast on under-inflated tires. More air pressure will keep that from happening.
Old May 18, 2009 | 01:34 PM
Steel Horse
the Max PSI was 65. I kept it at 60. A plenum gasket???
Old May 18, 2009 | 01:43 PM
lv360ram's Avatar
lv360ram
my LT tires are 65psi also but at that psi they are too stiff.
so I keep them at 35psi
