Electrical problem... Please help.
Old Nov 13, 2010 | 02:10 PM
BackwoodsRam's Avatar
BackwoodsRam
Try cleaning out the light sockets with a brillo pad or a wire bust ud be amazed at how just a little corrosion can mess things up
Old Nov 13, 2010 | 08:08 PM
gunner77's Avatar
gunner77
What you need to do is the plugs that are not working get a probe for a multimeter (Fluke 77/BN is one of the best) and check for continuity through out the circuit, could be you have a short to ground which will be easy to find out, but a pain to actually find the short itself. Rechceking fuses is going to get you no where they are either good or not. When you do this put a probe in the plug (or socket) and the other probe on the truck frame (or any clean metal surface) if you have continuity (ohms) then you have a short to ground. If you have an open (OL) then you are good to go on that particular leg of the wiring.
Old Nov 16, 2010 | 11:58 AM
wwilde's Avatar
wwilde
checked continuity and replaced multifunction switch still no joy guess my next step is re-wiring the brake/turn signal lights.
thanks for the replies
