Removing a spring?
Old May 25, 2009 | 11:20 PM
SilverRam_01's Avatar
SilverRam_01
Default Removing a spring?
I tried to search I promise:P.... Anyone just remove a leaf outta the rear springs to drop the rear of the truck down a little. I'm not concerned with the ride quality, I just want the hind end to be level with the front, and I want it to be cheap, and or free. Anyone done it? Is it hard?
Old May 26, 2009 | 12:01 AM
speeddemon31176's Avatar
speeddemon31176
Get a leveling kit. If you remove a leaf you will be deteriorating the load capacity of your truck not to mention that the rear end will probably end up lower than the front if you do. I am not saying you can't do it but for the couple of bucks it cost it would be wiser in my opinion to raise the front end to get level.
Old May 26, 2009 | 12:14 AM
EndIsNear's Avatar
EndIsNear
And leveling it is probably twice as easy. At least the advantages are more ground clearance, factory ride, and same load capacity. Looks are twice as good in my opinion! You can get a 1.5" for like $50. And a 2.5" for around $120, but needs new shocks.
Old May 26, 2009 | 01:45 PM
helms's Avatar
helms
new shocks arent necessary, they are just recommended.
