Best bolts for hitch
Old May 26, 2009 | 12:33 AM
BlueDemon01's Avatar
BlueDemon01
Default Best bolts for hitch
I just bought a class 3 trailer hitch on craigslist for 50 bucks, the guy took it off his 1997 SS/T 1500. The only thing was he doesn't have the bolts to go with it. So, what kind of bolts should I get and where are they avaliable?
I've heard forged titanium bolts from lowes work but I'd like to get an opinon from a dodge driver
Old May 26, 2009 | 12:42 AM
speeddemon31176's Avatar
speeddemon31176
Go to NAPA or some other quality parts store or bolt company and ask for grade 8 fastening hardware. Bolts, washers, and nuts. Get whatever sizes you need in grade 8 or better. That is all that holds whatever your towing in place in the end. The bolts at Lowe's won't do it unless they have grade 8 but I don't think they do.
Old May 26, 2009 | 07:46 AM
97black_ram's Avatar
97black_ram
I bought grade 8 from Home Depot and thats what holds my hitch on the Chevy k20 3/4 with no problem.
Old May 26, 2009 | 08:04 AM
speeddemon31176
There ya go. If you have a Home Depot near you, you could get grade 8 bolts there from what I have read above. I didn't know they carried them.
Old May 26, 2009 | 10:11 AM
PurplDodge's Avatar
PurplDodge
I went down to Lowes and bought some Grade 8, Zinc coated, Fine thread bolts.
Old May 26, 2009 | 02:50 PM
sungod's Avatar
sungod
The challenge you are going to find is in keeping the bolt from turning. Stock bolt as well as what you get when you buy the hitch have a tab to keep the bolt from truning without trying to get a wrench on it.
Old May 26, 2009 | 03:45 PM
PurplDodge's Avatar
PurplDodge
I almost forgot; I used lock nuts.
Old May 26, 2009 | 05:03 PM
Optimus's Avatar
Optimus
At least some of the hitches I've seen online (such as at etrailer.com) use carriage style bolts with a large square washer that keeps the bolt head from turning.
Old May 26, 2009 | 05:59 PM
BlueDemon01
Alright thanks a lot guys, I think I'll go with the same setup at PurplDodge
Old May 26, 2009 | 07:40 PM
Gwub2005's Avatar
Gwub2005
Here is the pdf for that same hitch and its not a huge problem getting the bolts from free spinning b/c the frame is a C and not closed off, so an open end wrench will hold them perfectly.
File Type: pdf
