Air Cond shuts off when going up hill
Old May 26, 2009 | 07:29 AM
Obiejuankinobie's Avatar
Obiejuankinobie
Default Air Cond shuts off when going up hill
I was trailering my two motorcycles to Eureka Springs AR when I noticed my air conditioning when stop work when I would go up a hill. As soon as I would level off the air would come back on. Has this happen to anyone else????
Old May 26, 2009 | 07:56 AM
ron333's Avatar
ron333
I believe it has something to do with the drop in vacuum in the lines operating the AC controls due to the drop in manifold vacuum under those conditions. I seem to remember something about adding a check valve in the line to maintain vacuum during these conditions to help eliminate this condition. I'm sure someone will chime in who knows more about this...
Old May 26, 2009 | 09:23 AM
Silver_Dodge's Avatar
Silver_Dodge
Yup, you have a vacuum leak. I'll bet if you look a little closer, it's not actually shutting off, it is switching to the defrost vents. Try the search feature, and you'll get tons of threads about vacuum leaks. This is a pretty common problem on our trucks.
