i think i need a new tranny..need help
Old May 27, 2009 | 04:26 PM
96dodgeramsport's Avatar
96dodgeramsport
Exclamation i think i need a new tranny..need help
any time i go from D (drive) to R (reverse) or any other gear my transmission gets stuck..then it makes this loud noise like it hits something and only then can i drive away, other wise it seems like i put it in neutral till it kicks in
do i need a new tranny??? if so whats a good reliable transmission i can buy and what would be the total cost..??
thanks, Eric
Old May 27, 2009 | 05:29 PM
zman17's Avatar
zman17
Retired Moderator - RIP
If it's a 4wd the transfer case could be bad.
Old May 27, 2009 | 09:07 PM
mrcribbs's Avatar
mrcribbs
What about Part to gear? When it "kicks in" does it run and shift fine?
Old May 27, 2009 | 10:38 PM
96dodgeramsport
nope its a 2wd
Old May 27, 2009 | 10:40 PM
96dodgeramsport
yeahh it does..it runs fine it shifts 1,2 etc.. it has no problem shifting my problem is putting it into gear it gets like stuck or sumthin
Old May 28, 2009 | 03:03 AM
dakotas ram's Avatar
dakotas ram
is it just when youre on a hill? i use my parking brake b/c mine is hard to shift into gear once it rolls a little bit and tightens up the linkage
Old May 28, 2009 | 04:11 PM
96dodgeramsport
nope...at any radnom time it will do that
Old May 28, 2009 | 05:48 PM
zman17's Avatar
zman17
Maybe you should check out the linkage going to the tranny. You could also have an internal problem inside the steering column. Mine broke internally and I had to replace the column.
I think there is a little confusion as to what is actually going on here.
Old May 28, 2009 | 07:22 PM
dakotas ram
so, it actually goes to the gear? then it wont go? or its hard to shift it to the gear?
