Lift Blocks?
Old Jun 2, 2009 | 07:19 PM
nathangfnd's Avatar
nathangfnd
mmmk well sorry for the confusion.
I want to take out the 4 inch blocks and put in the 5.5 inch blocks.
As for what i do with it- Its mostly a show type truck(Daily Drive/Project Truck)
I dont want to spend a large amout of money.
As for indexing ring. I have been meaning to order one just have been working alot lately so have had no time to order or install.
The shocks are the one from the RC lift. I was wondering if they will work with 3.5 inches of extra lift(1.5 inch higher blocks, 2 inch add a leaf)
I have been told about the driveshaft- Does anyone know if im able to measure how much more lift i can do without having to get it lengthened( lengthening it will not be a problem, just dont want to do it and find out i have to wait to drive it.)
Old Jun 2, 2009 | 07:25 PM
nathangfnd's Avatar
nathangfnd
as for body lift......
I was debating on if i should or shouldn't.
Are they hard to install.?.. Anyone got instruction.? My local truck accesories place does not install them. i have talked to them but they wont do it. so i was going to try an easyier way to get some lift
I want 40s so i need some clearance.
Old Jun 2, 2009 | 08:01 PM
speeddemon31176's Avatar
speeddemon31176
A body lift isn't the hardest thing to install. You will have to lengthen the steering shaft and make other adjustments. They come with pretty good instructions. The bigest issue you will likely face are the rusted bolts going through the body mounts. You will probably have atleast one that you will have to open up the floor to get at a welded nut that has spun loose. Any more suspension lift from where you are now will definitely require a longer drive shaft. You will end up waiting to have it made because you won't know the length you need until you take your measurements.
Old Jun 2, 2009 | 08:11 PM
nathangfnd's Avatar
nathangfnd
I was under the truck a week or so ago deciding if a body lift was a good idea. The body mounts actually all looked really good. None were rusty looking and and the black rubber piece(whatever you call it) is in really good shape.
IDK if the previous owner changed them out but they dont look 10 years old...
Old Jun 2, 2009 | 08:17 PM
speeddemon31176
If you decide to go with a body lift I hope for your sake they have been replaced and the po was smart enough to anti seize the bolts. Not saying that you will have a problem but it is very common to have issues with older vehicles in doing a body lift and havin the body bolts be rusted solid.
Old Jun 2, 2009 | 08:47 PM
dakotas ram's Avatar
dakotas ram
you can get a 3" bodylift from summit for around $160 or so......heres a write up
http://pavementsucks.com/tech/bodylift.php
Old Jun 2, 2009 | 11:03 PM
95MaroonMonster's Avatar
95MaroonMonster
when your lifting to this height, a better option than extending the driveshaft, is to order a SYE kit, and a tom woods shaft, with a double cardian joint on the t/case end like on the front
