Electric Fan Info Thread.
#122
when all of your original testing is done with the stock setups, i was curious if you would be able to take the a/c radiator out and test an electric fan setup that way. I took my whole a/c system out, and with the stock clutch fan, the temps have steadied down alot and at idle, the temps are cooler(obviously, the resistance of air compared to obstructions is less). so after all your testing is done, just curious if you'd be able to test it. i'm sure it won't matter anyway, because any fan that you test WITH the a/c radiator and deem worthy will be more than enough for my setup anyway lol.
(kinda pointless post i guess)
#123
Thought I would have started testing last weekend, finally have everything I need, but I've been wrapping up some long term projects at work and it's been eating up a lot of time. Hopefully will have that done by next week, and should be able to get going by the weekend of the 4th.
#125
#126
#129
Just an update.
Way behind from where I thought I'd be and haven't had the free time I thought I would this weekend, so little progress. At this point, all I've done is start to build the test set up that's Ram specific, here's a shot of that so far:
![](http://i727.photobucket.com/albums/ww280/hutch1973/014-1.jpg)
Have it set up so the a.c. condenser snaps in and out to be able to test w/wo easy. Just working on the mounting set up for the radiator. Basically, need to get a mount set up so the radiator pops on the end of the duct. Then I can mount the fans off the radiator the same way any of you would in the truck. Using this set up, I can easily mount and remove the factory fan shroud to get an idea of how it affects fan performance.
The 'duct' length is currently 6 foot. I expect to have to cut it down once I get everything up and testing to better simulate the front of the truck, although it shouldn't be much. I'll be drilling holes in the top of the duct towards the end to insert my instrumentation to measure the airflows. On the top of the duct right now is the power supply, and a smaller 15" duct I built to do some '0' readings. Won't publish those numbers because of some legal issues, won't get into that too much here though.
I won't have any issues posting the airflows of Ram Specific testing. Hoping to wrap up the test duct work this week, and get some testing done next weekend.
Also, with the smaller 15" duct, working on a mount to the backside of the radiator for that. Then I'll cut some inserts to slide inside of it. Using that, I can cut the hole in the inserts for the fans, and slide them back and forth inside the smaller duct to simulate different depths of fan shrouds to see how they affect performance. Probably won't get into that specific testing for a couple weeks though.
For now, wife went down in the basement and found my mess, and I'm in trouble..lol...will spend the rest of my free time this weekend cleaning. Women.
#130
Hutch - I know you have put in a lot on this e-fan project and it must fit into your priorities but anxiousness dictates that I ask if you have made any progress on your cfm testing.
Particularly, I am interested in your Perma-Cool 19115 test. I have been of the belief that mounting such a fan in the throat of the existing shroud would supply a sufficient airflow (unconfirmed of course) to maintain cooling on my 4.7L and any engine using the same size radiator. My personal reasoning is the shroud maintains a tunnel for the intake/exhaust of the fan ... being at least 12 inches from the radiator, the fan blades would be combating less surface turbulence than if next to the radiator fins.
In a nutshell, I am a fan (no pun intended) of your project and wait anxiously for any results, premature or otherwise, that you can provide.
cheers,
rovman
cheers,
rovman
