Another "truck wont start" thread
Old Jun 13, 2009 | 11:36 PM
  #21
speeddemon31176's Avatar
speeddemon31176
Either ignition switch or starter wire is damaged, corroded, or broken in between ignition switch and starter.
Old Jun 14, 2009 | 12:24 PM
  #22
RonRacer's Avatar
RonRacer
how hard is it to change an igniton switch???
Old Jun 15, 2009 | 03:26 AM
  #23
speeddemon31176
It isn't bad at all. You take the cover pieces off around the steering column and put your key in the ignition and turn it forward to the first click then insert a pick or something similar into the hole in the front of the ignition assembly and pull the ignition key assembly out. Then unbolt and unplug the ignition switch and remove. Reverse procedure to install.
Old Jun 15, 2009 | 03:28 AM
  #24
dodge15004x45.9's Avatar
dodge15004x45.9
Dam speed you know yr stuff. now if u would get on aim i have some news.
