Looking for the best set of replacement fog lights for my 97 ss/t
Originally Posted by zman17
If you are looking to replace with OEM .Check out rockauto.com , mine is not a sport and I currently have aftermarket cheapo's. But I have a pair of factory lites I bought from them , waiting to go in.
I have a 1997 Ram Sport and need to replace the factory fog lights. They measure 3 7/8" diameter. I see most after market direct replacements say they are not for the sport model or just say they are for a 1997 model. I've seen some listed as being 3" in diameter but most don't list a diameter. Does anyone know if Dodge has different size fog lamps for the Sport and other models for 1997 or are they all the same size?
I've been looking for a set for my 97 also..want the best set out there or oem
not to thread jack, my truck don't have fogs, is it possible to wire them up into the factory light circut, so i could have a cleaner install??
Not sure if they're all the same, but if yours is like mine, all of the wiring is already there. I bought a switch and installed it in the dash right next to the Overdrive switch. The plug to connect to the switch was just laying back there. The connectors for the fog lights themselves were zip tied behind the bumper, but I cut them off and wired up some after market fog lights.
Reason: Sorry, I just noticed that I replied to a post that was 10 years old.
Just got my set in from kool vue..home run for our 97 sports.ch2592109 ch2593109
Those look like OEM replacements. Are the built any better?
Pretty much identical. For the money I spent, if I ever needed another set I would buy same ones again. And they come with the 37 watt bulb like factory not like the cheaper ones with 27 watts
