dana 44 question
Old Jun 8, 2009 | 10:37 PM
mikey0469's Avatar
mikey0469
Default dana 44 question
so tommorrow i plan on changing all four of my ball joints along with a drivers side axle seal. i was just curious about pulling that axle out. does the dana 44 have a c-clip axle?
Old Jun 8, 2009 | 10:47 PM
speeddemon31176's Avatar
speeddemon31176
No c clips but you need a special tool to change the axle seals on them. Some of the guys on here have made their own axle seal tools. Try doing a search for the tool and you should come across it fairly easy.
Old Jun 8, 2009 | 11:18 PM
dhvaughan's Avatar
dhvaughan
here you go.
no c-clips.
axle is bolted in out at the hub.
special tool is required on the passenger side, drivers side is pretty straightforward except you have to remove the diff.
http://www.pavementsucks.com/tech/axleseal.php
http://www.pavementsucks.com/tech/hub.php
Old Jun 8, 2009 | 11:28 PM
mikey0469's Avatar
mikey0469
yeah i am aware of that tool. i have it. how is this axle held in though?
Old Jun 8, 2009 | 11:44 PM
speeddemon31176
The axle is held in place by the hub bearing assembly and axle nut. You can pop the ball joints loose and pull the axle and knuckle all in one shot but it will be heavy as hell. The other option is to take off the axle nut then remove the knuckle then the axle shaft. Be aware that the axle may be left hand thread for the axle nut. Some are and some aren't.
Old Jun 9, 2009 | 01:48 AM
mikey0469's Avatar
mikey0469
now is there a inner and outter axle seal on the drivers side?
Old Jun 9, 2009 | 02:33 AM
speeddemon31176
I believe that there are dust seals at the ends of the main axle tube but I can't remember for sure and believe it or not i just had a bat in my house and the little sucker took me forever to take care of him.
Old Jun 9, 2009 | 03:36 AM
mikey0469's Avatar
mikey0469
haha...what do you mean "take care of him" speeddemon? i can just picture somebody running around a house swatting at those damn things...kind of funny!!
Old Jun 9, 2009 | 03:43 AM
speeddemon31176
Actually I broke the broom and cut my hand in the process. By "take care of him" I meant i killed his ***. think of what it takes to break a broom handle and imagine that I broke it when I hit him with the broom. Little rat with wings.
Old Mar 10, 2010 | 03:54 PM
mnewbolds's Avatar
mnewbolds
"That Tool" that everyone keeps talking about. I can't seem to find one anywhere unless there is a NAPA or Advance auto part number for it, nobody seems to know what I'm talking about. I know people have made their own but I will be paying for a cab to get to the store so i don't want to get the wrong things. Anyone help?
