Need Headlight wiring diagram for 1997 Dodge Ram 1500
Old Dec 4, 2013 | 01:25 PM
Originally Posted by kallisto
Hello guys,
would it be any chance to repost the wiring diagram for Dodge Ram 1500 from 1997, please? It's all a little bit complicated.. my BF does not speak English and I do not speak technician, and I'm not sure that if I'd make a new thread I'd be able to explain reasonably the issue. There was some immobiliser tumor implanted on our car somewhere in Germany once upon a time.. then we brought the car to Czech Republic. Then suddenly the high beam lights turned on for ever (with "normal lights" being "hot".. like.. well.. turned on too), although everything is "turned off", like fuses, etc.. the high beams turn off only when the battery is disconnected.. geez, I beg your pardon to have such a stupid way to explain, but all we need is '97 1500 ram wiring diagram and this is the only forum I've found while being new to this..
Thank to anyone who helps in advance, guys.
Sarah
Hi Sarah.
Have a look in the FAQ/DIY forum here, there you will find the Service Manual thread. You can download the 96 factory service manual from there. It will be pretty much the same as your 97.
Good luck. And welcome to DF!
Old May 8, 2016 | 06:04 PM
brandonbraley's Avatar
brandonbraley
Default i need help please
hi i have a 99 ram 1500 and im putting a mm plow on it i got a used wire harness for the plow but the ends was cut off and i have to hard wire it to the lights and i need to know what color wires on the truck lights do what please thank you for your time
Old May 8, 2016 | 06:12 PM
You can download the factory service manual for your truck from here.
Welcome to DF!
Old May 8, 2016 | 09:23 PM
Friar Tuck's Avatar
Friar Tuck
Lightbulb Links to Manuals
What HeyYou said
Also, more manuals:
https://dodgeforum.com/forum/3rd-gen...-catalogs.html
Enjoy!
Old May 14, 2016 | 01:19 AM
brandonbraley
thank you for the help heyyou and friar tuck
Old May 16, 2016 | 10:21 AM
shak's Avatar
shak
The "Front Lighting" index starts on page 773 of the PDF, which is section 8W-50-1 using the manual's reference numbers. The schematics are on subsequent pages.
