Hell Bent leveling kit installed
Old Jun 16, 2009 | 04:26 PM
  #21
95MaroonMonster's Avatar
95MaroonMonster
IIRC, when we did the lift on my dads truck, the only thing we had to do was adjust the drag link to recenter the steering wheel, but his steering system is different, toe was not affected
now if you lifted like 4 or more inches, i could see it affecting things, when we lifted my friends jeep 6 inches, we had to do a driveway alignment before it could even be driven safely
Old Jun 16, 2009 | 04:51 PM
  #22
Cereal Killer's Avatar
Cereal Killer
Originally Posted by Miami_Son
Toe is the one suspension setting where there is the most flexibility and this small amount of lift isn't likely to upset things enough to matter.
Yeah I see where you're coming from. Especially if you just got it done 3 weeks ago. Everytime I take my truck offroad I probably knock it out of toe more than you possibly could have putting those spacers in.
Old Jun 16, 2009 | 05:02 PM
  #23
Miami_Son's Avatar
Miami_Son
Bingo! Alignment on a 4X4 is good for about 15 miles or the first parking bumper you hit.
Old Jun 16, 2009 | 05:39 PM
  #24
95MaroonMonster
right, or in my case, the first curb i drive over at school
Old Jun 16, 2009 | 05:41 PM
  #25
sungod's Avatar
sungod
Yeah, I know. The thing is that a 2" kit on a 10 year old truck basically nets you about a 1-1/4" lift when you factor in the sag. I just had the alignment done 3 weeks ago, so I'm not too worried. Toe is the one suspension setting where there is the most flexibility and this small amount of lift isn't likely to upset things enough to matter.
Seems to be a lot of guys in here who parrot things they read on the internet instead of having any real hands-on experience.
Wait, I thought you said that it wouldn't change? Oh, that is right, you were wrong. Toe on a SFA is the only setting you can adjust (point of reference is that there is a difference between adjust and change). Anytime you change the ride height you change caster. Anytime your caster changes, your toe will change (unless you happen to be running zero toe angle). The fact that you had it aligned 3 weeks ago makes this change even worse. Your alignment 3 weeks ago adjusted it to the specs based on the ride height at the time which includes the 10 years of sag. That is why you should have your alignment checked every 12k. I don't know how much lift you actually gained, but I can bet you that your toe was slightly positive before and after adding an 1 1/4 to the front and doing nothing to the rear that your caster has changed and probably pushed your toe negative.
Apology accepted.
Old Jun 16, 2009 | 05:46 PM
  #26
95MaroonMonster
Apology accepted.
Check your alignment ever 12K, yer an idiot (said like Walter from jeff dunham)
Old Jun 16, 2009 | 05:57 PM
  #27
Cereal Killer
I can't even believe you just said that. Jeff Dunham is ****ing hilarious dude. I'm gald other people know who that is. I seriously start to forget he's the one making those dummies talk sometimes. Ac<phlem>med the dead suicide bomber almost made me crap my pants.
Old Jun 16, 2009 | 06:03 PM
  #28
95MaroonMonster
haha that is perfect
to sungod SILENCE, I KILL YOU!!!
Old Jun 16, 2009 | 06:11 PM
  #29
sungod's Avatar
sungod
Oh really? please explain. Funny how out of the entire post that is the only thing you think you know more than me about. so come on genius. please explain the harm in checking yoru alignment every 12k and why that is so dumb?? You like buying tires???
Old Jun 16, 2009 | 06:17 PM
  #30
95MaroonMonster
well, lets see, i put a lot of miles on my rig for work and at 50 to 60 bucks a pop for an alignment, more depending on the shop, that gets real expensive, and my tires are wearing just fine, nice n slow
i only do alignments when i replace tierod ends or get new tires put on it
