Replaced blowout with BFG. same size, but taller will this cause damage??
Old Jun 16, 2009 | 09:47 AM
tresvatos's Avatar
tresvatos
Default Replaced blowout with BFG. same size, but taller will this cause damage??
I had one federal couragia 285/75 16 mud tire blow the sidewall out, so I got a TreadWright BFG mud/ all terrain 285/75/16 to replace I. The BFG measures about an inch and a half to two inches taller than the rest of the tires. I have the BFG on the rear right passengers side.
Will this small difference in height cause any damage to the axle or drive train?
Thanks
Old Jun 16, 2009 | 10:05 AM
dodge15004x45.9's Avatar
dodge15004x45.9
I can see the truck pulling to one side.
Old Jun 16, 2009 | 10:09 AM
Ram80's Avatar
Ram80
Also premature tread wear.
Old Jun 16, 2009 | 10:43 AM
sungod's Avatar
sungod
I assume your are 2wd. It not smart, but it won't hurt. I would be more concerned with running a retread than slight difference right to left.
Old Jun 16, 2009 | 01:45 PM
aim4squirrels's Avatar
aim4squirrels
sounds like it's time for a one-wheel smokey burnout!
Old Jun 16, 2009 | 02:14 PM
Miami_Son's Avatar
Miami_Son
If you have a limited slip it will wear out prematurely. Both tires on a limited slip axle need to be at or very near the same diameter or the axle shafts will turn at different speeds and fool the differential into thinking one wheel is slipping. This will wear the clutch pack out over time.
Old Jun 16, 2009 | 04:35 PM
tresvatos's Avatar
tresvatos
I have a 360 , 1500 $x$ 1996.. Don' t know if it has limited slip???
tresvatos's Avatar
tresvatos
I have a 360 , 1500 4x4 1996.. Don' t know if it has limited slip???
Old Jun 16, 2009 | 09:25 PM
Ram15002ndGen's Avatar
Ram15002ndGen
Look on the deferential, I believe there is a metal tag bolted on one of the bottom bolts that tells you if it's a limited slip.
