ABS light, brake light and speedo problem.
Old Jun 16, 2009 | 05:59 PM
drop_zone's Avatar
drop_zone
Cool ABS light, brake light and speedo problem.
Have a 99 extended cab Ram 1500 and the ABS light is on, the brake light is on and the speedo will only register speed above 40 mph. It has a new tranny. Was wondering what causes this! Any ideas? Could the rear differential sensor can cause this problem?
Old Jun 16, 2009 | 06:12 PM
RonRacer's Avatar
RonRacer
i just had a similar situation with mine where all that was happening + windows didnt work and it wouldn't crank up. i had my ignition switch replaced and he also did something to the starter relay and fuse(think replaced those too)
Old Jun 16, 2009 | 07:06 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Replace the sensor on the rear diff.
Old Jun 16, 2009 | 07:13 PM
Kindschi's Avatar
Kindschi
Ditto TO what Zman said.
On the top of the rear diff you will see the rear speed sensor (mine had a bracket wiht brake lines held on by the same screw), its like a 20 dollar part at the local stealership and takes 5 min to replace.
Old Jun 16, 2009 | 08:51 PM
Ram15002ndGen's Avatar
Ram15002ndGen
Do all 1500's have that rear speed sensor or only the 4x4's?
Old Jun 16, 2009 | 09:23 PM
J415's Avatar
J415
This question has been answered a million times. Now a million and one. I suggest using the search feature next time you have a question.
Old Jun 16, 2009 | 09:33 PM
Ram15002ndGen
Dude, I only asked the question because it was part of the thread. There is no need to dump on me for that. It would be silly to do a search for something that is already being discussed.
Old Jun 16, 2009 | 11:33 PM
J415's Avatar
J415
It was meant for the person who started the thread. no need to feel personally attacked. Newbie's alway want the answer now and are to lazy to do the search themselves.
Old Jun 17, 2009 | 03:48 PM
Ram15002ndGen
Ok. No harm, no foul.
Old Jun 18, 2009 | 02:57 AM
J415's Avatar
J415
No ****...JK.
