Talk about a stubborn nut!
Old Jun 16, 2009 | 10:50 PM
HDRAMman's Avatar
HDRAMman
Default Talk about a stubborn nut!
This has got me pissed and delayed.....any suggestions? I tried everything, Heat, PB blaster soak, air gun.......F'in thing wont budge. 3 ton jack wont even move it! Myself and my neighboor have never seen anything like it. Trucks only a 2001 too?
Old Jun 16, 2009 | 10:53 PM
speeddemon31176's Avatar
speeddemon31176
Lots more heat and use the airgun on it and go reverse forward over and over. It will eventually move. You could borrow a 1" airgun.
Old Jun 16, 2009 | 10:57 PM
95MaroonMonster's Avatar
95MaroonMonster
id say get a long *** cheater bar, and try that, thats what i had to do
Old Jun 16, 2009 | 11:16 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Can't bust a nut, eh?
You're going to need an air impact that will go upward of 300-ft/lbs.
Old Jun 16, 2009 | 11:27 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Get a longer bar and take off the tire so you can get a better angle on it.
Old Jun 16, 2009 | 11:45 PM
cdusthockey's Avatar
cdusthockey
i had the same problem, and a 4 foot cheater bar didnt even work, with 2 guys bouncing on it. i eventually got it off with a 3/4in impact. it took about 2 sec give that a try
Old Jun 17, 2009 | 02:08 AM
Cereal Killer's Avatar
Cereal Killer
Put a 6 foot long piece of pipe over your breaker bar and get your shoulder under it.
I'm sure the impacts would work too, but I'm thinking if you had one handy you'd have used it already.
Old Jun 17, 2009 | 08:14 AM
Magnumpwr16's Avatar
Magnumpwr16
I hearya man i just went through this.....gonna need a highly powerful impact gun and heat....what i did was heat it up for a good minute and then instantly switched over to the socket and impact before u lose too much heat and it came off, slowly, but it did come off. good luck.
Old Jun 17, 2009 | 09:04 AM
charlie1935's Avatar
charlie1935
Saw the heading on this thread and I thought "Damn, some one on here knows me"!
Old Jun 17, 2009 | 09:29 AM
Sheriff420's Avatar
Sheriff420
the pb is a waste of time, that stuff is useless. i use CRC Knocker loose and its the best penetrating fluid i've used so far (haven't tried them all). i haven't seen a nut or bolt stay stucks with that stuff yet but i'm gonna do the same job your doing in a couple days so we'll see if its as good as i hype it up to be.
also, zman swears by cyclo penetrating fluid. he's been using it for 30 years so it must be some good stuff.
