No Turn Signals
Old Jun 17, 2009 | 12:44 AM
Ramman18's Avatar
Ramman18
Default No Turn Signals
A friend of mine's mom has a 95 2500 4x4 V10 regular cab long box with 150k miles.
The turn signals don't work at all. The hazards work fine and she's replaced the fuse and bulbs.
When the signal handle is pulled on, I can hear one 'tick' like it wants to blink but won't.
Is the switch bad in the column? We don't know where to look. Any help is appreciated.
Oh and the blinker fluid is topped off
Old Jun 17, 2009 | 02:28 AM
jasonw's Avatar
jasonw
Site Moderator
The next thing I'd do is replace that lever. $45 ish on eBay or at a junk yard, and a fairly common thing to go wrong.
Old Jun 17, 2009 | 02:38 AM
Diefenbaker's Avatar
Diefenbaker
First recheck the fuse in the fuse block (the one between drivers door and dash panel). At this fuse block there are also two identical relays. One for turn signal the other one for hazard. Interchange them. If the turn signal works now the relay is faulty. For more detailed wiring check this at page 17
Old Jun 17, 2009 | 05:09 AM
speeddemon31176's Avatar
speeddemon31176
+1 on checking the relay first. Then change the multifunction switch if the relay doesn't fix it.
Old Jun 17, 2009 | 12:50 PM
Ramman18's Avatar
Ramman18
Thanks everybody, we'll keep you posted.
Old Jun 19, 2009 | 12:45 PM
Ramman18's Avatar
Ramman18
Tire shop fixed it right away. It was some little $5 switch. I think it was called the turn signal instrument. Anyway, they work great and she's happy. Thanks.
Old Jun 21, 2009 | 11:00 PM
goober86442's Avatar
goober86442
What was the part that they replaced? i am having the same problem but my dodge is a 99 ram 1500 so it a multi hazard/signal flasher which i have replaced.
Old Jun 21, 2009 | 11:20 PM
wjxavier's Avatar
wjxavier
huh?
Old May 10, 2013 | 09:21 PM
Diamond8's Avatar
Diamond8
Has anyone ever figured out what the switch was he replaced?? I am having this EXACT same problem. Running lights work........flashers work.......turnsignals quit......when I move the turn signal lever I can here the relay "click" but not flashing? Any help would be greatly appreciated!!
Dave
Old May 11, 2013 | 12:41 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The flasher is what they most likely replaced.
