oil light ,help?
oil light ,help?
Hello, iam a new forum guy ,I love these forums they are very helpful , with that said I need your help....
I drive a 1997 clubcab 4x4 5.2 5sp its got just 200x klms
just today when I went to stop the oil light came on ? it happened 4 time and stalled once( not sure if it was the truck or me with the clutch)
Its got oil its in the safe zone on the dipstx so whats up anyone know??
thx hope you can help
Trending Topics
UPDATE
Ok I replaced the oilpressure switch ,and did a oil / filter change
other than knowing I have a new oilpressure switch and clean oil nothing changed
When I come to a stop it drops very low revs and the oil light comes on and 50% of the time it stalls
If i come to a stop and disengage the clutch and coast to a stop its fine ?!!!
Is there a sensor or switch thats cheep that i could replace first and go from there ?
thx
thx
Thats weird. Its fine untill you stop..(with the clutch disengaged) And then when you do stop it idles real low??? And then the oil pressure light comes on? Am i correct?
If im correct:
Maybe, since it is idling real low then thats why you have low oil pressure. The lower the rpm the lower the oil pressure. The higher the rpm, your oil pressure will be higher. So is it idleing way lower than its supposed to idle? Have you gave it some throttle while your stopped in the truck somewhere like at a red light and got the rpm up to regular idle and seen what your oil pressure is? Have you tried that???
If im correct:
