Quirky starting?
Old Jun 21, 2009 | 11:36 PM
dakotas ram's Avatar
dakotas ram
http://www.autozone.com/autozone/cat...hText=solenoid
Old Jun 21, 2009 | 11:40 PM
SarcasticDwarf's Avatar
SarcasticDwarf
Great!
Can anyone explain what exactly this thing does?
Old Jun 22, 2009 | 04:00 AM
Sheriff420's Avatar
Sheriff420
that looks like that little whatchamacallit behind my passenger headlight attached to the fender.
Old Jun 22, 2009 | 02:53 PM
dakotas ram
yep the newer trucks have it on the fender and the older ones are kinda behind the aircleaner
Old Jun 22, 2009 | 03:05 PM
dakotas ram
heres mine, its a 95.......i looked at an 01 today and it was on the fender with big hoses going to it.....mine are small
Old Jun 22, 2009 | 03:53 PM
PurplDodge's Avatar
PurplDodge
Love your valvecovers, Dakota.
Old Jun 22, 2009 | 04:17 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by dakotas ram
mine does the same thing.........ive heard that the map sensor has a part in starting
I was just going to post that same thing in that MAP sensor thread. I've already stated I noticed no improvement in bottom end, and won't know about MPG increase or if there is more power when in OD ,until later this week or next. BUT, lately my truck has to turn over a few more times every morning to start(starts right off after that for the rest of the day), I too thought the pressure regulator was going bad again . But after I installed the new MAP the other day, it fires right up instantly in the morning now.
Of course the OP still needs a fuel pressure gauge to check the regulator. Don't want anyone spending $80.00 for nothing.
Old Jun 22, 2009 | 04:59 PM
SarcasticDwarf
Huh? Is the procedure documented somewhere?
For what its worth, I intend to replace my MAP later this year anyway.
Old Jun 22, 2009 | 05:31 PM
zman17's Avatar
zman17
HUH! what? Are you talking about the fuel pressure? If you are , it's in a 15 dollar Haynes manual, and if you have a fuel pressure tester I can tell you the procedure. You screw it in to the test port on the fuel rail , should be around 49 pounds pressure. Then after the key is off you watch the gauge and see if it drops in pressure quickly. or it holds for a good amount of time, shouldn't drop 5 pounds in 15 minutes or so.
Old Jul 16, 2009 | 06:26 PM
striperfishing's Avatar
striperfishing
I am having similar starting problems and after reading this thread I checked the evap system and found a huge hole in the charcoal canaster. I can't beleive those things a 100 bucks. What would happen if I just bypassed it?
