Steering Stabilizer Removal
Having a hell of a time removing the tapered end of my FACTORY steering stabilizer from the inner tie rod of my '95 3/4 ton 4x4 (106k miles). I soaked it in PB Blaster, beat the tar out of it with a hammer, tried a pickle fork, and heated it up with a torch and it didn't even budge. Any tips/tricks? Its so frustrating i'm considering buying all new tie rods to avoid the hassle.
Same thing here. It's frozen in place where it's pressed into the drag link. I tried using a pitman puller like the manual said and I bent the damn puller lol. Gotta love salty winters that seize everything. Any ideas? I don't have a torch, just one of those blue Bernz-o-matic things you use to solder pipe. I could cut it off but then the bolt will still be frozen in the drag link.
Rob
Rob
Trending Topics
Do you think the dealer will be able to order me just the bolt? I would just go to the hardware store but it's a weird bolt with a sort of spacer built into it to keep the strut out away from the drag link, and the washer that goes on the backside of the eyehole is part of the bolt as well. I didn't get new hardware with my shock
Rob
Rob
