Changing crankshaft sensor
Old Jun 24, 2009 | 11:57 AM
Granta1's Avatar
Granta1
Default Changing crankshaft sensor
I am changing the crankshaft sensor. Does anyone have tips on doing it. Looks like a pain to get to,
2000, 1500, 5.2, auto
Old Jun 24, 2009 | 12:55 PM
audiomechanic's Avatar
audiomechanic
The bolts also have a torx head cut into them. I forget the size. I think it's a 25. You'll need it for the rear bolt as a socket on that one will bind against the head as you're removing it.
Also, a socket swivel is your best friend.
Old Jun 24, 2009 | 02:34 PM
gobbell1's Avatar
gobbell1
mine (5.9l w/46RE) was located at 10 o'clock (looking at the firewall from the front of the engine) and was held in place by a bracket with 2, 1/2" or 9/16" bolts.
I used about 18" of extensions and attacked it from underneath. If you can get a 2nd set of hands, have then loosen/tighten the bolts from on top while you place the socket on the bolts from underneath.
You can see pics here...http://my.att.net/p/s/community.dll?...pid=404015&ck=
Old Jun 24, 2009 | 04:04 PM
donnyrob's Avatar
donnyrob
I changed mine not long ago. Mine had bolts with a 1/2 inch hex head and 1/4 inch allen head bolt. You can't use a 1/2" socket because something is to close to the bolts (I can't remember what it was ) but I got a long 1/4" screwdriver bit and ground the screwdriver part off, slid it into a 1/4" socket (if you have a 1/4" allen socket you wouldn't have to do that) with a 6" extension. I did mine all by feel cause you can't see anything due to the firewall, and it wasn't a big deal. I may have had to take out the bellhousing bolt holding the tranny dipstick too. It seems like it was in the way.
Old Jun 24, 2009 | 04:49 PM
audiomechanic
Oops! Donnyrob is correct, the bolts have an allen head cut into them, not a torx. Sorry about that.
Old Jun 24, 2009 | 07:33 PM
RockRam2500's Avatar
RockRam2500
If it is anything like the 5.9 you will need a very long hex wrench, I struggled with different positions for several hours trying to get a good attack position on it. It's just in a crappy spot plain and simple cant see the bolts you are going after and buried back by the firewall.
Old Apr 28, 2012 | 10:49 AM
Holly Magnum's Avatar
Holly Magnum
do the bolts go into the fire wall, the block or the tranny. this little sensor has me beyond confused
Old Apr 28, 2012 | 10:51 AM
Augiedoggy's Avatar
Augiedoggy
block.... right at the edge where the tranny bellhousing bolts up...
This is where I was thankful to have my body lift...
Old Apr 28, 2012 | 10:52 AM
zman17's Avatar
zman17
Retired Moderator - RIP
The block. Get a small mirror , you'll see it better. Not gonna try unscrewing the o2 huh?
Old May 14, 2012 | 04:55 AM
Mikelord861's Avatar
Mikelord861
The body lift saved my life
