help - the brakes failed
I was driving along and noticed that the brake & ABS lights were on, and though I never did like the stopping power on the truck it seamed to be harder to stop. I checked the fluid & found the rear Reservoir low and the front empty.
I see a wet area that appears to be coming from between the chasis & tank, so I assume that the brake line for the rear wheels is leaking.
The real question--- Can I change the brake line without taking the fuel tank out??
Yes you can, but IMO it's not worth it to be safe. You can remove the tank and install an OEM line, or if you have tubing benders and the correct flaring tools, you can do it without removing the tank. Of course you won't be able to mount the line to the frame without removing the tank. So it will vibrate , and eventually rub through if you are not sure it's not hitting anything.
I just replaced the same brake line. It was leaking in the same spot. I just bent the line myself, and abandoned the old line behind the tank. Removed everything that wasn't behind the tank. I wrapped the entire new line in 3/8" rubber fuel line to protect it. Use what clips I could.
Upgraded to 1-ton dually wheel cylinders at the same time, and bled the brakes. The truck stops better than it ever did before.
What's the deal with these brake lines, and why do they seem to keep leaking? After replacing them, I'm sure you guys have found out what caused the break, maybe it can be prevented?
Trending Topics
They just rust through. It's usually in the same spot between the gas tank and frame. I suppose the road debris that sand blasts the rest of your brake lines doesn't get up there. The lines I replaced it with are stainless steel, and the section I placed behind the gas tank is zinc coated. Not to mention everything but the connectors, and where the line is clipped to the frame is covered in rubber hose.
The old line lasted 14 years. I figure the new one is good for at least the same
