Worst Stuck
#42
here are a few
we got our BIGGEST tractor stuck twice in the same day (pipeline had just went through, and any of yall farmers with one in a field know what im talking about)
im talking about a tracked 355 horsepower CAT that would make my truck feel like a speed bump if i hit it
it took my uncles big 4x4 JD to pull it out
another one, we got a JD 4955 stuck in a field with a pipeline, spreading potash, it required the use of our big White 4-150 with a Cat 3208 V8 diesel to move it
IIRC we also had a tire fall off the 4955 once, the lugs broke (the rim was shot)
the 4955 also got sunk up to the top of the hood, only the front, you couldn't even see the front tires, cant remember what pulled it out (it was before i could remember)
we also had a combine many years ago, that had both axle shafts break clean off the machine, in one day, we had one fixed, and took off, and the other broke not 20 feet later
#43
And this guys is why you must be careful with tow straps...
http://break.com/index/strap-breaks-....html?matchid=
#44
on
and this is a good example of how not to pull someone out
http://break.com/index/wrong-way-to-...chid=?matchid=
#49
