Gearing = ?
Old Jun 27, 2009 | 11:52 AM
Steel Horse's Avatar
Steel Horse
Default Gearing = ?
ok im confused on how the gearing works! For say, i want to put bigger tires and keep or get more torque what gear ratio should i use? i have 4:10. should i go to 3:56 or 5's?
Old Jun 27, 2009 | 12:20 PM
HellaciousHemi's Avatar
HellaciousHemi
Deep gears (4.10s and beyond for example) give you the "hole shot" or quicker accel but have a lower top speed. Taller gears (2.73s for example) give you higher top speed with slower accel. I am sure many on here have their own gear ratio they like for their application. Just gear it for what you will be using the truck for most to get the best results. You might have to adjust your speedo also.
Old Jun 27, 2009 | 01:00 PM
Ram15002ndGen's Avatar
Ram15002ndGen
I would guess the factory gears give you a decent low and top end mix.
Old Jun 27, 2009 | 01:05 PM
Cereal Killer's Avatar
Cereal Killer
Your ring and pinion gears determine how many times your drive shaft will spin per revolution of your tires. With 4.10 gears your driveshaft is spinning 4.1 times each time your tires does a complete revolution. With 3.55 gears it's spinning 3.55 times.
So for bigger tires you want lower gears, like 4.56 or 4.88
Old Jun 27, 2009 | 02:37 PM
Steel Horse
ah...ok. thanks so much guys
Old Jun 27, 2009 | 03:15 PM
wjxavier's Avatar
wjxavier
what axles do the off-road editions come with? i know if you have a chrysler 9.25 axle...you'd have to get a different carrier for anything higher than 4.10
Old Jun 27, 2009 | 03:34 PM
Steel Horse
1994-2001 Rams used a solid front axle. its a Dana 44 CAD. (Center AxleDisconnect) The rear is a P.O.S. chrysler corporate 9.25" If i recall correctly i dont know if that goes for the off road though too
Old Jun 27, 2009 | 11:27 PM
dodge15004x45.9's Avatar
dodge15004x45.9
I think they do.
Old Jun 28, 2009 | 12:49 PM
wjxavier's Avatar
wjxavier
yea...if thats the case, you've got the lowest gears you can get with that axle...anything lower and you'll need a bigger axle
Old Jun 28, 2009 | 12:54 PM
Cereal Killer
You just need a bigger carrier. Or "thick" gears.
