Home stretch still same problem
Old Jun 30, 2009 | 12:21 PM
CSXfan's Avatar
CSXfan
Sounds like a giant vacuum leak to me. Carefully spray carb cleaner around any vacuum lines like 2damnyankee said, when it revs you have found your leak. I had a 1994 3.9l Dakota that would idle like that when the coolant temp sensor was unplugged, could be something as simple as that. Good luck.
Old Jun 30, 2009 | 01:01 PM
dakotas ram's Avatar
dakotas ram
theres also a gasket between the tb and the manifold
Old Jun 30, 2009 | 01:45 PM
dodgeram2001's Avatar
dodgeram2001
i know i could be wrong but do u have fuel filter on that if so check it thats one thing u could do just saying its probably not ur problem but u never know
Old Jun 30, 2009 | 03:27 PM
Wickedwiggles's Avatar
Wickedwiggles
I think the hissing is the air filter b/c when I had it open element it didn't make that hissing sound but still did the idle till death maneuver. Also yes there is a gasket b/t the filter andthen again b/t the IM and the TB, so 2morrow I will go and check these IAC and TPS and fuel pressure.
Old Jun 30, 2009 | 04:38 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Did you do away with any cats in your exhaust system? And if you didn't are they new and if not, have they been checked? I don't remember your past post's about the o2 sensor(s).
Old Jun 30, 2009 | 10:29 PM
scarynickname's Avatar
scarynickname
I had the exact same thing happen to me. It was on a 93 Grand Cherokee with a 5.2 magnum. My problem was two injectors that were stuck open. Drain a little oil out and see if it's been thinned out by fuel.
Old Jul 1, 2009 | 03:10 AM
Wickedwiggles
Z I put a brand new magna flow cat on and ran it 2 in 1 out exhaust still dumped.
Scary how did you fix it?
Old Jul 1, 2009 | 03:32 PM
Wickedwiggles
Alright the IAC is good and I got fuel pressure......Scary I m on to your suggestion about the injectors how did you fix it? (bought new ones? lol)
Old Jul 1, 2009 | 06:24 PM
jasonw's Avatar
jasonw
Site Moderator
How about the TPS?
Old Jul 1, 2009 | 09:48 PM
scarynickname
I traded it for a 66 Plymouth Fury.
